- May 20, 2006
- 22
- 0
- 0
Hi all, long time since ive posted on here but as ive just upgraded and getting back into the OCing scene thought it revisit for some advice.
So i just go myself a new mobo (Asus P5NE-SLI), E6750 and 4gb of Corsair CM2X1024-6400.
So far ive been running the cpu @3.5GHz on 1.456v and its orthos stable for 8 hours. however, when i push it to 3.6GHz its no longer stable in orthos but seems fine everywhere else...
temps @3.5GHz never exceed 37c under full load and @3.6GHz never exceed 40c so i know that temp should be limiting me but i dont want to over-volt
is this the most i can get from this cpu or is there a bit more i can squeze from it?
to monitor temp i use both core temp and asus pc probe II (asus probe gives higher readings than coretemp and those are ther ones ive listed)
any help is much appreciated
BTW old rig was Asus A8N-SLI with AMD 64 3500+ - what an upgrade huh!!!
Intel all the way for me now!
