max venice vcore?
DrMrLordX
23,240
13,326
I believe 1.4v is the spec voltage for venice cpus. You can always check AMD's technical documentation if they have any online.
fluxquantum
2,398
i run mine at 1.525 but 1.55 hasn't hurt it either. i just don't need to run it at 1.55, but some folks need more voltage for added stability. :)
jiffylube1024
7,430
1.6 or less. I ran my 3000+ @ 2.6 Ghz, 1.6V (which is what it took to be totally Prime stable), but backed it down to 2.52 Ghz/1.535V. Temperatures are actually quite similar at the different voltages on an XP-90.
1Dark1Sharigan1
1,466
Mine's running @ 2.66GHz with 1.59v but can run @ 2.6 Ghz @ 1.5v . . . so generally speaking I would probably run it most of the time @ 2.6 Ghz 1.5v and only @ 2.66GHz+ 1.59v when benching . . . high vcore is not a big problem if you have excellent cooling (or watercooling) as long as you don't cross the 1.6v barrier too much . . .
Oct 17, 2005
102
Mine runs at 1.65V @ 2.5GHz only.
I tried running at 1.5~ but it wouldn't pass prime if I did that...
I guess I got a bad chip.
Icepick
3,663
4
The rule of thumb is that it is safe to increase the voltage on the CPU by 10% over default. The Venice default voltage is from 1.35-1.4 Volts depending on the proc. That puts the safe operating range up to 1.54V for your processor.
1.4V*10% = .14
.14V + 1.4V = 1.54V
The manufacturer engineers the processors with a tolerance of + or - 10%. That's why most people agree that you can increase voltage by that much without risk of damaging it.
