VirtualLarry
Just upgraded a friend to an X2 3800+ (939) CPU. His heatsink (from a 3000+) is an all-aluminum block, no copper, no heatpipes. Currently overclocked to 2.65Ghz, from 2.0Ghz. According to CPU-Z, the vcore is 1.4v, although the VID default is 1.35v, and I have the BIOS set to auto-detect default volts. Perhaps the board (Biostar 939 NF4) overvolts.
Anyways, the temps are reading 70C for Core1 and 79C for Core2, with CoreTemp 0.95.4.
I used Kingwin thermal paste, a dollop in the middle of the core. I didn't spread it around. I wonder if that could be part of the problem.
Amazingly, it's prime-stable in this condition, so I'm thinking just leave it alone. What do you think?
Oh, CoreTemp reports a TCaseMax of 73C too. So if AMD's also have an ~15C delta between TCore and TCase, then I'm probably just barely alright.
Edit: Ugh, core2 just hit 83C. That seems too hot to me.
The heatsink is almost too hot to touch, so I guess I'm making good thermal contact with the CPU. It seems that the stock heatsink/fan is not quite up to the task. Should there be an 11C difference between the cores?
