MAx temp for 2,8C?
MotoFast
Hi!
I have a p4 2,8C with a Zalman 7000A-Cu and i did set up fsb 250 at 5/4 in bios at stock voltage 3,5ghz, running rock stable but i think its maby to hot.. it will run abot idle 43 and when run prim95 i hit about 59,5 is that to high? Had in mind to try to clock higher... is ther dangerous if it hit around 62 degrees?
Hmm and i dont think the zalman is doing so well or is it.. i dont now so much about this..
