R Retro2001 Senior member Jun 20, 2000 767 0 0 Sep 25, 2002 #1 What is the max cable length of an Svideo run? Also, if the max length is over 4 meters, where can you buy longer cable? Thanks will
W wedi42 Platinum Member Jun 9, 2001 2,843 0 76 Sep 25, 2002 #2 i bought a 50' cable from trianglecables.com it was $10 + 7 s/h 50' is beyond spec for svideo but it works ok. i get some artifacts, but i don't know if it is from divx or the cable.
