My temps are fine and I see other people pushing their voltage beyond 1.5volts, but I've heard that pushing the volts is a bit risky. As long as my temps are down, should the chip be safe, or could the high voltage alone kill the processor? Thanks.
Originally posted by: ariafrost
I've read that 1.5V-1.55V is generally considered the max safe range for X2's. Then again, if your 100% load temp is only 43C you may be able to push it to 1.525V-1.55V with no trouble. Remember though that voltage increases increase the OC a lot at first but yield diminishing returns later. Also, higher voltage reduces chip life.
Originally posted by: John
What he's saying is that even if you were able to run 1.55-1.65v you may not be able to achieve a higher overclock. I personally would not run above 1.6v.
Are your temps full load temps taken while running Stress Prime or Prime95?
Originally posted by: Zaitsev
What are you monitoring temps with? Because that sounds a little low to be a core temperature. I'd recommend downloading Speedfan and check your core temps before you crank the voltage.
