Max Resolution of Intel G3258 Onboard Graphics?
Burpo
4,223
473
2560x1600p i believe.. The IGP is simply listed as Intel HD Graphics, with the GPU offering half the number of execution units (just 10) as its K-series counterparts
https://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics
4th generation Intel® Core™ processor family
(Intel® Iris™ Pro graphics 5200 / Intel® Iris™ graphics 5100, Intel® HD graphics 5000 / 4600 / 4400 / 4200)
DisplayPort* 1.2 / eDP*
H-Processors: 3840 x 2160 @ 60 Hz (Ultra-HD)
U-Processors: 3200 x 2000 @ 60 Hz, 3840 x 2160 @ 30 Hz
Y-Processors: 2560 x 1600 @ 60 Hz
HDMI*: 4096 x 2304, 3840 x 2160 @ 24 Hz / 24bpp
DVI: 1920 x 1200 @ 60 Hz
Termie
7,949
48
www.techbuyersguru.com
Effectively, it's probably going to be 1920x1200. Most motherboards that you'd use a G3258 with (i.e., low-end and midrange boards) won't have DisplayPort, and the DVI connection is apparently limited to 1920x1200.
Fun Guy
1,210
FYI, I am using this info to purchase a monitor for a new low-power workstation based on this processor. Ideally I'd like something better than 1920x1080, but if the onboard graphics can't handle anything greater than that, then there is no point.
Burpo
4,223
473
It's not that the IGP won't handle it, the board has to have DisplayPort for higher than 1920 X 1200 @ 60Hz..
OBLAMA2009
6,574
alternatively you just go out and get a cheap ass video card and not worry about what the on board graphics can do
Fun Guy
1,210
It's not that I don't believe you, I would just like to see the specs on the G3258 in black-and-white myself.
FYI, my MB is the ASRock B85M-ITX, which has HDMI and DVI. Am I am limited by the fact that this MB does not have a display port?
The Mini-ITX case & PS only have 90W total to work with, so an add-on video card is out.
Termie
7,949
48
Yes, nothing higher than 1920x1200 for your board. The specs of the G3258 aren't the determining factor here. The port is.
Burpo
4,223
473
This is from the intel page..
Shivansps
3,918
1,570
yes, stick with 1920x1200, go to mATX and get a H81 with DP, or just get the HP Stream Mini if you are looking for a tiny workstation.
VirtualLarry
56,587
10,227
But while the CPU may support it, the mobo and ports have to too. And the sad reality is that most, don't.
Fun Guy
1,210
Burpo, can you post the link to where you got this? Thanks. :)
*So, since I have an HDMI port, I should be able to get greater than 1920x1200, correct?
Burpo
4,223
473
You can get 2560 X 1440 working with HDMI 1.4, but it takes some tricks (CVT_RB Timing & Refresh @ 55Hz)
http://www.notebookcheck.net/2560x1440-or-2560x1600-via-HDMI.92840.0.html
xthetenth
1,800
529
If you're buying a better than 1080 screen, it's probably best to get something that'll let you do that rather than spend way more on the price of a board that'll do it or an add-on card and not be happy with it.
Shivansps
3,918
1,570
But you cant return your board and exchange it for the MSI with DP? its just $5 more.
escrow4
3,339
122
A Pentium workstation? Isn't that a contradiction?
