Max Payne sound reversed
HouRman
691
On a computer with a sound blaster Live card (Gamer, Not 5.1) while playing Max Payne, the surround sound is backwords. For example, close by sounds are whisper quiet while far away sounds are loud.
The computer has the following:
Windows XP
Latest Max Payne patch
Latest SB live drivers
Had similar problem with windows 98SE and unpatched Max Payne.
Any Ideas, it's the only game that's like this?
flood
4,213
<< reformat. >>
errr... did you try defragging your hard drive?
Oyeve
22,078
888
What the hell do reformating and defraging have to do with this? And you guys are diamond and platinum. Sheesh. Try making sure there are no settings in the game to reverse sound or something like that. Patch the game, or try reinstalling it.
