Hello..
I am going to be buying a 2.53 gh system (as most of you probably already are sick of my questions ;p) that will be used for Ocing in the future. I am going to use a Swifttech MCX4000 for my heatsink and either a YS-Tech 80 MM w/ speed control rated at 3w, a 80 mm blue led fan rated at 6.5 w, Or possibly a Thermaltake Smart Case Fan II rated at a max of 8.4 W.. How much can a 3 pin CPU Fan header on a ASUS P4PE take? And if I need a different method for these fans, where do I hook them up? And if I don't hook these up to the CPU header will I loose RPM or any other monitoring tools? And finally, can these CPU fans be hooked to a 6 port baybus for further speed modifying? Thanks everyone, sorry for so many questions but this is my first home built system, want to do it right! Thanks.
