- Nov 18, 2005
- 251
- 0
- 76
I heard that the maximum amount of RAM that any mobo can actually use is 4 Gigs. Can someon shed any light on if this has changed?
Originally posted by: TheArabian
XP Professional
what do you mean it wont utilize it? So its pointless to go over 2.5 gigs? And if so what OS will utilize it
Ok well who cares what Prof recognizes, lmao i just checked the bios and everything looks good. So i dunno i guess i wont be able to get a screenshot of 12 gigs ram on my system properties, oh well... hmm i guess i should photoshop it in lmao
Originally posted by: Oyeve
They are many mobos that go way beyond 4gb. Tyan makes one that can take 16gb of ram. It is also a dual socket 939 mobo so can actually take 2 dual-core AMD cpus and in theory have 4 cores and 16 gb of ram. Now that is sweet.
that would make more sense. with ms, you can upgrade your license to x64 for free, but you lose the 32bit one. the regular windows xp pro can only recognize ~3GB of ram max. Just get your it guys to get you an image of windows x64. why waste all the ram?Originally posted by: Bobthelost
If it's a multi billion dollar company then get the IT division to do you a new XP 64 image.
