mATX MB for Xeon X5560...Help!!!
HammerZ
144
Hi,
I was able to obtain a Xeon X5560 CPU for a really good price. I am thinking of building a new rig to replace my existing Q6600 system in an Antec mATX case. I like the overall size of teh case and low noise levels. However, I cannot seem to find any mATX MB out there that supports a X5560. Can anyone recommend a mATX MB that will work with a X5560 Xeon processor? I don't need dual CPU sockets and will probably only need 12GB RAM max. No SLI or XFIRE required either. Thanks in advance for your help.
arkcom
1,816
That's just a quad nehalem. It should work in almost any 1366 motherboard.
Dec 27, 2004
181
www.store.massiverc.com
No, many boards don't like Xeons, for some reason. Possibly CPU support in the BIOS.
Yep, you need BIOS support for it (even if it's unnofficial). I know the Rampage Gene series supports the 9xx Gulftowns as well, so there's a very high chance a 6-core Xeon will drop in no problem.
