I want to build a PC that only uses m.2 SSD. No need for HDD/DVD. Here is what should fit in:
Something like a small FD Refine, but shorter and lower. Ideally price and quality are not worse than Fractal Design. I don't care for a window, but it wouldn't be a dealbreaker since my planned build would be very neat. Since this build doesn't really require much actual building, I also would look at a lower quality than FD if needed.
It seems most cases are still built for HDD. I realize people still buy them new, or have old ones. But I want to build a PC that has the absolute minimum only and has a case as small as possible. I don't want an ITX case, since I want to use the cheaper and more available mATX hardware. Without HDD space it should be possible to make an mATX case almost as small as an ITX case. I also recycle my main rig hardware (mATX) in this smaller build. I realize this case will be useless for someone who needs 3.5" drives.
the closest what I found is this Rosewill FBM-X2 for around $40 it holds 1 HDD, so they could still make it a bit shorter without that HDD space. I'm also not sure about the PSU dust filter.
Please point me in the right direction. Thanks.
- Maximum board size would be mATX
- ATX bottom-mounted and easy to maintain filter
- one to two 2.5" SSD
- iGPU or a smaller graphics card
- ideally 2 front 140mm fans, alternatively 2 120mm fans. Easy to maintain filter. A bottom fan with easily maintainable filter also would be good.
- air cooling only. I assume since the width is a minimum due to the ATX-PSU, it may fit a 120mm cooler. Alternatively 92mm cooler may be OK. Not looking at more much than 65W TDP CPU.
- Easy to clean air filter for all intake fans inc. PSU. Something what Fractal Design does with the Define units would be great.
