Mattress directly on top of a slatted bed?
Leros
21,867
7
I bought a bed that has slats across the bottom (see example below if you don't know what that means).
The guy at the furniture store told me I can put my mattress directly on top of it. The guy at the mattress store says I should put 1/2" plywood on top to provide a solid base for the mattress. Who is right?
Example of a slatted bed (mine has similar sized gaps).
Born2bwire
9,840
Huh, dunno. I had to buy a new queen mattress a few months back and I found that the mattress itself felt a little floppy compared to the old ones that I have had in the past. Course with a small gap in the slots it probably doesn't matter but then again getting a piece of plywood won't cost much either. I'd probably just look at what the warranty on the mattress says.
33,132
If that bed is made by the one company that seems to make all those platform beds for all the companies that sell those platform beds you should be able to buy an extra slat set to fill in the gaps. That's what we did when we bought ours and we put the mattress directly on it.
nageov3t
42,808
83
if the crossbeams are screwed into the bed frame, I'd throw the mattress on top and not bother with plywood.
Leros
21,867
7
i have a bed like that, i just put the mattress on top, seems to be fine
Yeah, my mattress is on top right now. It seems fine.
Every other slat is is bolted down and the slats are connected by a vinyl strip. There are legs running under the middle to provide support to the floor.
zinfamous
111,748
31,116
slats are fine. I had placed super thin plywood under a new foam mattress for worry of the slats causing a problem, only to discover that the flat surface created a wonderful place for mold to grow.
removed, created air flow, all is fine on slats.
Colt45
19,720
Why would you put plywood on it? The factory would do that if it was superior... They are slats intentionally.
DirkGently1
904
If the slats are sturdy it's fine to leave it as is. Mine is cheapo pine and a couple of the slats broke pretty quickly. They're easily replaced though.
drebo
7,034
We have a queen mattress on top of slats, but are thinking of getting a box spring with our next mattress. It's a little uncomfortable at times, and the crossbar is bent now, too.
blackdogdeek
14,453
10
we have a king mattress directly on top of slats with a memory foam mattress topper. it's all awesomesauce.
corwin
8,644
9
How about a box spring and then mattress on top of that?
Seriously..who doesn't use box springs? And WTF is with the mold comments? How do you get moisture under your mattresses?
OK...seeing the "wet the bed" post maybe I shouldn't wonder so much...
ussfletcher
2,569
Everybody sweats in bed, a lot, probably more than anyone would guess.
Drako
10,697
161
We have 3 beds in out house, and none of them have box springs on them - they are all platform beds like the one shown in the OP.
ElFenix
102,398
8,566
why would i use a box spring on a bed that's designed not to use one?
