Matrox g400 tv-out plus PAL = NOT WORKING
BDSM
584
I just wanted to inform you peeps that the otherwise wonderful tv-out/DVD-max provided with the g400 dual head range of cards from Matrox will not function properly with playing DIV/x files if you are using PAL.
Playback will be choppy no matter what you do and what drivers you use.
Some ppl seem to have it working for them but many don't. So if you are planning on getting one for use with the pal system check it out really carefully first or you will have a useless card on your hands.
ps.Matrox says there are drivers coming to correct this but I don't believe them because judging by what they are saying in the forums they seem to know as little or less about the problem than most users.
