Mathematical Problem - Geometry Involved
Duckers
2,089
I found this puzzle somewhere and I thought it would be fun to share it with you guys.
Imagine any triangle, divide each side into 3 equal parts. Now draw a line from each vertex to the right-most divider.
In terms of the original triangle, what is the area of the smaller triangle in the middle?
Picture: click here - Hope it works now
Mister T
3,439
Duckers,
Its been over 3 years since I have touched the the law of sines....
Anyway, my answer is .368688946 of the original triangle...
This is derived from the following:
sin 60 / sin 100 - sin 20 /(3*sin60) - sin 100 /(3sin 60)
I might have made an error somewhere as I scribbled stuff over a couple pages...
Time2Kill
1,816
4
www.brooksidestorage.com
I just drew it up in an autocad program, made the sides of the traingle 3 inches long, so each divided section was one inch.
Then I connected all the points, and measured a side of the small triangle, which was 1.13389341902831 inches long. So 3/1.13389341902831 is 37.7964473009436666666666666666666666% of the original size or a 3:1.13389341902831 ratio
Time2Kill
1,816
4
Feb 7, 2000
1,004
the question states to solve the problem for "any triangle"
you solved the problem for an equilateral triangle. the correct answer should be in the terms of a, b, and c where a, b, and c are the lenght of the sides of the triangle
A5
4,902
Ok, my link USED to work, but I'll just go delete it now :p
Time2Kill
1,816
4
<< I just drew it up in an autocad program, made the sides of the traingle 3 inches long, so each divided section was one inch.
the question states to solve the problem for &quot;any triangle&quot;
But it doesnt say for the sides...the problem states:
