Math review help
LeetViet
2,411
What does it mean if a question has:
f(x)
does that count as another x value? what's the f?
Question is x = 5
does that mean x = 5 and y = 0 ?
f:x ->
and
g:x ->
hi5
28
Not funny ppl, i aint laughing cause i can answer that.
When ever u see things like f(x), its said as f is a function of x.
We use this term to represent Integral.
But since the value of X is given, use it on the equation.
Check the question because thier will be a full equation like f(x)= X + Y (something)
That doesnt mean Y=0.
If u paste the whole question here, i'll solve it for you:p
LeetViet
2,411
f(x) = 2x -1
x = 5
f:x -> 3x - 1
g:x -> 2x - 1
Thanks for your help!
Edit: My ASCII skills failed. The three dashes represent division.
Those are 4 different questions.
hi5
28
whats so difficult in that, can i ask ur grade and ofcourse ur age :p
Simply put X=5 in both eqaution,
2(5) -1 = 9
3(5) -1 = 14
Thats ur cordinate (9,14) although im still thinking what g stands for
What else??
LeetViet
2,411
11, 16 turning 17.
I don't understand why you used 5 for x in the other questions...
hi5
28
what other question.
please write correctly i thought it was the same.
zakee00
1,949
f(x)
Question is x = 5
f:x ->
and
g:x ->
you know whats crazy, i had the same HW tonight :confused:
yhelothar
18,409
39
f(x)
Question is x = 5
f:x ->
and
g:x ->
hmmm lots of people here in prealgebra..
Goosemaster
48,775
F(x) stands for a "function of x"
I.e y=mx , where y depends on what x is. X is the independant variable, and y is the dependant variable. Basically, whatever you get for x, determiens what y will be. That said, F(X) defines x as the independant variable.
For example, if I choose to plug in 5 or x, which is the same as saying x=5, then the function will start with F(5). Of course you must plug in this number to find out what it means. Think of it as a machine, or more speficially a function machine. You put something in, it processes it, and outputs something.
Assuming I use the equation f(x) = x+5 , that says that my independant variable will be modified by adding five to give me the resultant dependant variable. If x0, that will tell me what my y value is when x=o, or my y-intercept.
gutharius
1,965
Originally posted by: OverVolt
wow... they are insanely easy. Public or private school?
Sleeping in class? :)
Speak for yourself. It's the horrific language they use to describe these things that makes me freak out. When you say, "where y depends on what x is. X is the independant variable, and y is the dependant variable". First words out of my mouth are, "WTF! SPEAK ENGLISH!"
Goosman thanks for the laymen's interpretation of that. It cleared it up like crystal for me. Why can't mathmatics teachers learn to speak laymen or something? At least something understandable on a basic sense?
