Math question!! need help!!!!
WarDemon666
OK i have to change a number, to a time.
EX: 252331 is equal to 4 mins and 11 secs.
EX2: 283648 is equal to 4 mins and 11 43 secs.
Any ideas?
Thanks!
Originally posted by: Spencer278
divide by 60 to get number of minutes and then subtract total seconds - number of minutes * 60 to get seconds.
if u divide the first # by 60 u get a 4 digit number 😕
WarDemon666,
This makes no sense to me. What units are 252331 and 283648 in?
Edit: also what is "4 mins and 11 43 secs." in your OP? Typo?
Originally posted by: Kyteland
WarDemon666,
yeah. oops. lol..
4 mins and 43 seconds. for the second one.
ANd i dont know the units. but the "mcisendstring" gives me back that number when i get the position and length of a song.
thats the problem i have to figure out. lol
Originally posted by: WarDemon666
Originally posted by: Kyteland WarDemon666, This makes no sense to me. What units are 252331 and 283648 in? Edit: also what is "4 mins and 11 43 secs." in your OP? Typo?
yeah. oops. lol.. 4 mins and 43 seconds. for the second one. ANd i dont know the units. but the "mcisendstring" gives me back that number when i get the position and length of a song. thats the problem i have to figure out. lol
it's in milliseconds. divide by 1000 and you have seconds.
I still dont get the exact number as windows media player. the number goes up to 7 mins 80 seconds for some songs. lol
Can you give the bitrate and sampling rate of the songs? Maybe it's dependent on that? And for the 7 mins/80 sec song, how long is the song really.
Give a third example as well. I could give you an equation that would fit those two, but I can't guarantee it would work in every instance unless I have three examples.
483163 = 8min3secs i forget which one was 7 mins 80 secs long i was just goign through... thanks guys
emmpee already figured it out. It's in milliseconds.
ok so how do u convert it to mins, and seconds?
thanks.
Originally posted by: WarDemon666 483163 = 8min3secs i forget which one was 7 mins 80 secs long i was just goign through... thanks guys
ok so how do u convert it to mins, and seconds? thanks.
:Q
So if I told you the song was 483,163ms long, you can't convert it to minutes and seconds!?!?
Say your number is x
floor(x/60000) = Minutes
floor(x/1000) mod 60 = Seconds
Take 483163 as an example
floor(483163/60000) = 8
floor(483163 /1000) mod 60 = 3
Answer: 8 minute 3 seconds
Note that floor(x) where x is a real number is the integer portion of x
floor(8) = 8
floor(3.1415) = 3
floor(483163/60000) = floor(8.0527166666) = 8
etc.
:Q
Yeah, that's pretty sad.
X ms * (1 s / 1000 ms) = Y seconds
Y % 60 = Z minutes
Y - Z*60 = offset seconds
-silver
Y % 60 = Z minutes
-silver
That can't quite be right, if % = mod function
Y % 60 = Z (offset seconds)
(Y - Z)/60 = Minutes
You're right. I meant floor of Y/60 😛 I did the math right but put the wrong fuction down.
-silver
