MrControversial
This is a problem straight out of a math book...lol. Not really, but it sounds like it. See, I get paid mileage for some network troubleshooting that I do. However, I failed to record milage from one point to the next. Using Map Quest I figured out that it was 21 mi. from point A to B and 8 mi from point A to C. However, I don't know the distance between points B to C. So I basically drew a triangle and I ended up with a obtuse triangle with the length of two sides known and the length of the last side unknown.
I'm almost ten years removed from high school geometry and I can't remember if there are any geometric or trigonometric formulas for finding the length of one side of the triangle when you know ONLY the length of two sides. For you math whizzes who may be fresher at this stuff than me, here's the math problem:
This obtuse triangle has sides AB= 21 and AC = 8. What is the length of side BC given no internal angles? Is this problem even solvable?
