Math problem, please help, I'm stuck
Nocturnal
Please help me with this problem. It is bothering me and making me frustrated.
I'm following this formula: ax^2 + bx + c
#50 from 7.4
28x^2 - 28x + 7
This is what I did so far:
I use the grouping method because the trial and error method is too confusing for me.
So I found the GCF of 7.
Turned the problem into:
7(4x^2 - 4x + 1)
Next I start to do the grouping method.
I see that the constant is a positive or plus so I know that both signs of the two factors will be the same.
So I write out ac = 4(1) and that that 4(1) has to add up to -4.
2(2) will do it, well -2x(2x) = -4x.
Next step is to add in the -2x + 2x into the problem.
7(4x^2 - 2x + 2x + 1)
Now I find the GCF for the first two terms. The GCF is 2x.
2x(2x - 1) +2x +1
Then you find the GCF of the second term which is 1.
1(2x + 1)
So
(7)2x(2x - 1) 1(2x + 1)
THIS IS WHERE I GET EXTREMELY CONFUSED.
2x - 1 does not equal 2x + 1
Wait, I am looking at the problem now and I'm guessing it can't be factored?
It can't be factored because ax^2 - bx + c would mean that both signs would NEED to be -, -. Otherwise the problem can't work.
its a repeated root, the answer is x=1/2 and x = 1/2.
if you divide the entire thing by 28, you get x^2 - x + 1/4. easy to factor from there.
edit: spelling
I'm not even doing roots or anything. What I'm trying to do is called "Factoring Trinomials of the form ax^2 + bx + c, a is not equal to 1.
This is easy, you are just factoring incorrectly
you could factor out a 7 and get 7(2x-1)^2=0
divide both sides by 7, then you get (2x-1)^2=0
now squar root both sides sqrt of 0=0; thus 2x-1=0
add 1 to both sides; 2x=1, now just divide both sides by 2
and you get x=1/2
I already got it. Thanks guys for the help. Even reading a message board is hard. I have to physically do the problem to get it down. Thanks again though.
