math problem help
sonoma1993
I need help with this math problem,
Add the odd numbers from 5 to 371.
Hint This is an arithmetic series
here the answer I have a choice from
69184
34404
376
34592
68808
according to the formula im using n/2 * (a1 + an)
i get the answer 34968
Originally posted by: tfinch2
Are you including 5 and 371?
34968 - 371 - 5 = 34592, which is one of your choices.
-edit-
oops...sorry. the correct answer is 34592. that includes both the 5 and 371
LOL
pwned
why owned, it didnt say to exclude them, i would have most likely included them as well
You are supposed to include them. But sonoma1993 included them twice.
LOL
pwned
you're right...if you include both of them, the answer is 34592
I think it is the last one, but i am not good at sequences and series.
edit
nm, the last is if it is all numbers.....
im sure I included it into the forumla
i think the forumla should look somethen like this if not please correct it
188/2 * (5+371)
You're right, he did. I didn't even really look at the problem, just some logic based off his answer.
188/2 * (5+371)
Should be 184/2.
The number of numbers between and including the end points can be found by:
[(last # - first #)/step size] + 1
Here, it's (371 - 5)/2 + 1 = 184
188/2 * (5+371)
Should be 184/2.
cool thanks for the help.
188/2 * (5+371)
Should be 184/2.
No problem.
