math problem: help me figure this out. (now with paypal reward)
notfred
38,241
4
here's a math question for you guys (it's not homework):
You've got two circles with radii x and y, respectively.
these circles both have center points that lie on the X axis. their center points are separated by a distance d. you can assume that the left-most circle's center ponit is at 0,0 if you like.
Using x, y, and d, find the location of points u and v, where u and v are the points at which each circle would touch a straightedge that was set down on top of them so that it was resting on both circles.
I'd prefer to do this with just algebra and trig, and not calculus, if possible. I need to get a computer to do it, and I have trig libraries but not calculus libraries.
Edit: here's a diagram.
Edit2:
The points we are trying to find are not simply the highest points on the circles. They're the points at which a line that is tangent to both circles intersects each circle. I'll draw a more exaggerated diagram if it's still unclear.
Edit 3: diagram with more exaggerated radius differences
Edit 4: $5 via paypal to the first person who comes up with a correct answer with nointegrals or derivatives in it.
Goosemaster
48,775
Originally posted by: notfred
Originally posted by: Goosemaster
looks like pythagorean theorem
I don't want to know the length of the line, I want to know its endpoints.
is the straight edge parallel to the x axis?
I am assuming by straighedge you mean a ruler and that it might not be parallel
bobert
505
how will you find the endpoints if you don't give any relative location of the circles. do you want your end points in relation to the other circle?
Goosemaster
48,775
that is what it will have to be, but if the straightedge is parallel it is much simpler than if it is not
bobert
505
if the straight edge is parallel to the X axis and the center of each circle lies on the x-axis, that makes X = Y right?
hypn0tik
5,866
I'm assuming the radii are different, so the straight edge won't be parallel to the axis given that the centres of the circle lie on the axis.
I'm assuming something like this?
u and v are where the line intersects the circles and d is their centre to centre separation.
Edit: I should clarify, that line is tangent to both circles. Correct?
Goosemaster
48,775
we are all assuming different thigns:laugh:
hypn0tik
5,866
Yeah, OP really needs to clarify and include a picture so we're all on the same page.
Goosemaster
48,775
seriously
notfred
38,241
4
I just added a diagram to the OP. The center points of the circles are separated by a distance d. You can assume that the left most circle has its center point at 0,0 if that makes things easier.
chuckywang
20,133
The distance from u to v is sqrt(d^2 + (x-y)^2). Where is the origin in this problem? If you know where the origin is, it's a simple trig problem.
notfred
38,241
4
Origin is at the center of the left-most circle, and your equation is wrong, and I didn't ask for distance.
hypn0tik
5,866
It isn't too bad of a problem. Can be done with trig only.
RGUN
1,007
If we set the original to point u (0,0), then point v is 'd' across in the x direction and (y-x) in the y direction. Therefore with this point of view, the coordinates are u (0,0) v (d, [y-x])
If you want to use the center of a circle as the origin than you would have to use some calculus to determine where the lines become tangant to your circle.
edit, upon further inspection the d across would actually be [d + cos(theta)*x-cos(theta)*y]
hypn0tik
5,866
Hmmm, never mind. I thought you wanted the distance between u and v. Now that you want the actual locations, it's a bit trickier.
notfred
38,241
4
And what's theta?
chuckywang
20,133
The distance from u to v is sqrt(d^2 - (x-y)^2). Where is the origin in this problem? If you know where the origin is, it's a simple trig problem.
Sorry, supposed to be a minus in the sqrt. If you know the distance between u and v, you can find the coordinates pretty easily.
esun
2,214
I can't think of an easy way. There is a brute force way: iterate along the first circle, keeping track of your current coordinates and the slope at the point you're at. Come up with the corresponding equation for a tangent line, then check to see if you can solve that equation simultaneously with the equation of the second circle (to within some certain error). If yes, then you're done. If no, then continue iterating along the first circle.
notfred
38,241
4
$5 reward?
GOTTA BE HW
Yeah, it's a howework assignment for my Computer Networking class, since that's the only class I haven't already taken the final for. Also, after being here for 5 years and making 36k posts, I have a track record of lieing about homework problems all the time.
