Hey guys...I know there are some math-majors on here, so hopefully someone can give me a push in the right direction. Note: this is not for homework--I plan on taking this class (Complex Analysis) in the fall, and I'm trying to learn some of the material ahead of time to make it easier.
So...the problem... (E denotes epsilon, D delta)
For anyone that may need a reminder...what we're trying to show is the limit of f(z) = w0 as z->z0 by demonstrating that for any E>0 there exists a positive D such that:
|f(z) - w0| < E whenver 0 < |z-z0| < D.
The limit i'm trying to prove: limit of 1/z = i as z->-i.
So that gives me: |1/z - i| < E whenever |z+i|<D.
Then I know I need to try and get the |1/z-i| in terms of |z+i|...but that's where my hang-up is.
Through some manipulations...I've gotten that |1/z-i| = |z+i|/|z|...but there's still that annoying z term.
If I change it to |z+i|/|z+i-i|, I can do the triangle inequality in reverse and get:
|z+i|/|z+i-i| <= |z+i|/(|z+i|-1).
And there...I'm stuck. Trying to say D=E/k and substitute that into the above doesn't work out too good. Dividing top/bottom by |z+i| gets me something in the form of 1/1-x...but the power-expansion doesn't converge >.<
So with that, I've just about run out of ideas... Do I even have the right approach?? I don't want the whole proof...just a hint.
Thanks,
-Eric
Thanks,
-Eric
