Math geeks - help needed
Status
Not open for further replies.
Nov 5, 2001
18,366
Okay, I should know how to do this, but I don't, and I don't have time to try to figure out the formulas.
I have an arc with a 73' radius. I need to know for an 8' section of that arc, what the midpoint of the arc's distance is from a line across the end points. Or in layman's terms, how much deviation there is in the arc from an 8' line.
Anyone know how to figure this quickly?
JTsyo
12,019
1,126
8' line is a cord? Or is the 8' along the circumference?
Assuming its' the cord, drawing it up in ProE gives me .22' between the line and a line tangent to the curve.
TecHNooB
7,458
assuming i read that correctly, R - R cos(angle in radians / 2) might be your answer.
KMc
1,149
If 8' is the arc length, then the distance from it's midpoint to the chord of it's end points is 0.11'
Nov 5, 2001
18,366
THanks guys, you are correct, the 8' was the chord length...couldn't remember the term.
KMc
1,149
Well, technically, the answer to your problem is different depending whether the given length of 8' refers to the arc length or the chord length. But because the radius of this arc is so large, with a chord length of 8', the arc length is only 0.004' longer (8.004'). So, the answer comes out to 0.11' either way you do the calculations.
Lemon law
20,984
I was going nuts trying to figure why everyone was saying 0.11 feet were the answer and I kept getting 0.102. Until I realized I was solving for the 78 foot radius and everyone else was solving for 73 feet.
Status
