Math: Define average for me
Sep 29, 2004
18,656
68
Someone just broke my brain. How do you define average? I will update this thread later with what I was told. I want everyone elses unbiased opinion on this.
Calculate the average of:
1,2,3,12,12
UPDATED :
The other party said that average meant mean, median or mode. That those 3 things are all defintions of average.
35,612
Average usually is used to indicate the univariant mean. Given a series of n values of x, the mean is the sum of the values of x divided by n.
mean = SUM(x)/n
RPD
5,109
600
^ beat me to it. Median and average/mean aren't the same thing.
mvbighead
3,793
OK, that is one answer. A co-worker says there are two other formulas.
Co-worker is either an idiot, or a mathematician.
The average is always the sum of numbers divided by the count of the numbers. I can assure that the excel function does not have more than one way to calculate the sum.
What are the answers provided by the co-worker?
FirNaTine
639
185
sum of the numbers divided by the # of numbers
That would be the mean.
Also median would be 3 (half above and half below). Used to minimize effects of outliers on the mean.
12 would be the mode. The value that occurs most frequently.
Feb 6, 2007
16,432
The mean, median and mode are all technically averages; when the word average is used on it's own, it is most often used to signify the mean average. If someone asked me to find the average of a set of numbers, I would assume they meant the mean.
CPA
30,322
4
right, coworker is probably saying mean, mode and median are all averages.
Sep 29, 2004
18,656
68
THIS IS IT! But I have never referred to someone saying that mode and median as being the definitions of average.
vi edit
62,484
8,345
So does the calculator take off from the treadmill or not?
crownjules
4,858
I peaked at wiki. The only other thing is that he's breaking down the different types of mean (average) - arithmetic (your usual average), geometric, and harmonic. But that's really splitting hairs.
e;fb
Sep 29, 2004
18,656
68
Actually, just wiki'd and must say I am shocked:
http://en.wikipedia.org/wiki/Mean#Arithmetic_mean_.28AM.29
There are each of arithmetic, geometric, and harmonic means. Given a sample set of values, each calculates a different mean. I am not a mathematician, so the shit is greek to me.
EDIT: Each does use the word average in their definition... hmmm.
Yes, I found that also. My co-worker was referring to mean, median and mode though. All defintions of average.
Sep 29, 2004
18,656
68
e;fb
Nope, not the hairs he was splitting.
I did more looking up of things. There is something called central tendancy. That is mean, median and mode.
But even wikipeida presents it as kind of a grey area.
http://en.wikipedia.org/wiki/Average
But hte word average does not appear once on this page:
http://en.wikipedia.org/wiki/Median
RPD
5,109
600
This is what my coworker was saying. But I don't knwow what you are referring to with '^'. What else can average actually mean (no pun)?
The ^ is a visual way of referencing the post above the current one.
