I am constantly lagging out while playing MineCraft and it's making me lose my mind. We've purchased 18mbps which i think should be plenty to play MC, though speedtest.net is showing 11-13mpbs most times. It's not the minecraft server, everyone else on the server is playing fine, it's just me constantly lagging out.
Please help me boys I have a lot of information.
I need help dissecting what the actual problem is with my internet. Here's some information:
1. We've bought 18mbps from at&t, after doing multiple speed tests the typical download speed is 11-13mbps, is this normal? (We have multiple televisions so I don't know if this affects bandwidth, with that being said, most tvs are almost always off)
2. At&t put the wireless router in the back corner room of our house, I typically play Minecraft about 35-40 feet from the router, could the router be too far away?
3. I tried to change the wireless channel but the wireless security pw underneath the router is blatantly not working as the pw, with that being said, if I can gain access will changing the channel make a huge difference? I downloaded inssider or w/e and we are on channel 7, no one else is on this channel but there are a lot of people on 2,3,4,5,6, so could they be interfering?
Solutions:
1. Will one of those usb network things help my signal strength? Something like this: http://www.newegg.com/Product/Product.aspx?Item=33-704-...
2. Should I raise the bandwidth to 24mbps? I am hesitant on this, because 18mbps should be plenty to play minecraft, yet I'm lagging out constantly and making me rage.
3. If you all think the problem is the location of the router, is there an extender or something to move the wireless router?
Anyway, tl;dr: 18mbps, speedtest is showing 11-13mbps, wireless access point 35-40 ft from where I play minecraft, I keep lagging out on minecraft (its not the server), what is the best solution.
Solutions:
