Originally posted by: John
1) Don't do a repair install just yet
2) If all you're using is AVG & Ad-Aware then you're barely scratching the surface of malware detection and removal
3) Click on my sig and do everything in steps 1-8 to start, then look under the Virus Removal section for the two online scanners
AVG + Ad-Aware was used just to get the thing working. It's not my PC, and anything other than a super-easy-to-use solution would end up unused.
I'll try replacing adapter.dll, but it's missing two others as well, one of which is a known security exploit, the other unknown.
I'm wondering if the whole computer's so badly !@##!$@ed up that wiping the hard drive may be in order. To be quite honest, I usually just reformat in this type of situation, and that might be the wisest thing to do.
In the mean time? !$#!@$!@ this, I'm switching to Linux. Much, much, much less hassle.
So let me get this straight. You're
desperate but you don't have the patience nor the time to address the issue properly.
😕 Wiping the drive and doing a clean install is taking the easy way out, and unless you have an image be prepared to spend additional time (usually an hour or two if not more) installing all of the old software, configuring email accounts, tweaks, restoring old data, etc.
Switching to Linux because you cannot figure out how to troubleshoot Windows-related issues seems rather obtuse to me. Don't get me wrong, Linux is an excellent OS and I am just now beginning to use it myself. However as long as you use
common sense when dealing with a pc running Windows, and spend a little time learning how to troubleshoot, you'll come to realize that most problems exist between the keyboard and chair.
