I doubt that a few teaspoons per tank would do anything at all.Originally posted by: Minerva
Does adding a few teaspoons to a tank of gas really make any difference?
Originally posted by: Pacfanweb
No, it does nothing but help clog up your fuel filter. It's snake oil that's simply been around a long time.
Do you have any evidence or is this hearsay?
Originally posted by: ja1484
Government regulations require a certain amount of detergent additives in gasoline sold in the US anyway. Top Tier Gas is even better from an engine cleanliness standpoint. Adding "fuel injector cleaner" of any kind in modern engines is pointless. Adding engine oil additives is BAD.
Listen people: Car companies know how to build cars. They come with owner's manuals for a reason. Have you noticed not a single modern vehicle recommends fuel or oil additives in their manuals? I wonder why.
Listen to the manufacturer. They know what they're doing.
That's just sounds wrong in light of the financial mess the big 3 are facing.Originally posted by: ja1484
Listen to the manufacturer. They know what they're doing.![]()
If that were true, there'd be tons of threads posted with that information.Originally posted by: ja1484
These "one size fits all" additives will work, at best, average for some vehicles and poorly for others.
More likely, there will be no difference beyond a placebo effect.
Originally posted by: CurseTheSky
My Mustang's 289 V8 has around 80k original miles with no complete rebuilds that anyone in the recent ownership is aware of (just the normal stuff like fluids, carb, starter, fuel pump, etc.). When I first got it running, the lifters (flat tappet) were extremely loud. It sounded like someone dumped a bucket of bolts down the intake after you revved it, and it stayed that way for several weeks.
I put about 4-6 oz of Marvel Mystery Oil in the oil and down the carb. Within a minute only one lifter was still making noise, and it eventually stopped after several days. It also had a lot better throttle response and didn't start to choke at high RPM (probably cleaned the valves a bit). Several other people were standing there when I first poured it in (all skeptical), and everyone had the same "wow" response.
This stuff won't work miracles, but I definitely wouldn't call it snake oil. Whether or not there's something else that's cheaper and works just as well (ATF), I don't know. I was impressed, though. I was using it in much higher quantities than it recommended though (when I was dumping it down the carb, the engine was probably getting 80% MMO, 20% normal fuel), and I have no idea how it would affect a fuel injected engine.
There ARE plenty of threads around the internet about MMO and other things, like STP, being snake oil.Originally posted by: Blain
Does adding a few teaspoons to a tank of gas really make any difference? We use this stuff around the ranch on just about everything from air tools to small engines.
I don't need to show proof. Google is your friend. If you don't know that these sort of things are snake oil, then, no offense, but that simply shows a lack of knowledge and understanding about cars on your part. Sorry.
It's amazing to me that, as long as MMO's been out and has long been discredited as doing anything to help your engine or fuel system, that we still have this conversation occasionally.
Let's put it this way: ANYTHING you can buy at a parts store to put in your oil will not help. It's snake oil. ANY additive. Marvel Mystery Oil. Sea Foam. STP. Slick 50.
Anything that says it's "oil treatment", "oil additive", etc, is snake oil.
MMO has been known to be snake oil for so long, that it's like knowing the sun rises in the east. You don't need to watch the sun with a compass to prove it.
Nope. Sea Foam is not different. Just because something is popular and a lot of people use it doesn't mean it's not snake oil.Originally posted by: BlackTigers
I thought Sea Foam was one of the ones that actually worked? Just what I've read.
Listen my friend...Originally posted by: Pacfanweb
