Hi everyone,
I have some really annoying and frustrating problems.
I bought a new case, trasferred all the parts to the new case, and it didn't work.
After sevral testings with another motherboard and another cpu (exect same, I have 2 of each), I managed to get it to light up (motherboard is on the table) but no post and no beep whatsoever.
I'll list the parts I have no idea after all the testing I did if they are faulty or good:
1) 2x AMD Athlon64 3500+ CPU's, tested them both, on 2 motherboards and one mobo might be shorted.
2) 2x MSI neo2 plat skt939 mobo (one is fried for sure, the chipset fan doesn't spin), I might have shorted other parts when trying to connect them to the faulty motherboard.
3) X800XT All in wonder card, the fan spins but I have no idea if it works.
4) Corsair TwinX XMS dual channel 1GB memory, has LED's on the heatsinks to show when they are operating, needless to say when I tried to test the LED's did not light up at all.
Now, I don't know what to do.
I have 1 other computer that has SATA and windows2000pro so I can recover the data from the SATA HD's I used on the 3500+ computer?
Should I test the X800XT and memory modules on this computer as well, or do I rink frying components on this computer?
Is it normal to take the motherboards and CPU's to a computer store and ask them to test them? I don't want to assume i fried them and maybe throw out good parts.
I also have 2 power supplies, one might be faulty also, although it does light up, one is new which I bought yesterday but I also tried to test with it.
I'm really almost giving up... any ideas?
