You should be able to set it to "max battery" or some setting like that in the bios. However, I do not think the heat/performance ratio would be worth underclocking your processor. Check the bios. In order to access it if you don't know how, you usually hold a key like f2 during startup. It should say hold "F_" to enter setup before windows xp starts loading. Enter setup and play around it should be under a cattegory such as performance or battery consumption.
