I have a situation which is a little out of the ordinary. I have 6 wireless bridges (SMC 2891W-AG). I have 3 at our main office, and the other 3 are at 3 different locations. The 3 at the main office connect to a small 5 port D-Link switch along with the WAN side of a router. With the current switch everything works great, acts like all radios are on a local LAN, I can ping and access their web configurations all from the main office.
I purchased a new switch to replace the D-Link because the router we are going to be using needs a 10Mbps port which doesn't have auto-detect. I picked up the HP ProCurve 1700-8 because I could manually set the speed of a specific port. I am not using the VLAN or any of the other features. From the settings it appears everything is on VLAN 1 which basically means it acts a a non-managed switch on all ports I believe.
Now comes my problem. I swap out the D-Link with the HP, all ports light up properly. I plug my laptop into a spare port and see if I can access all the bridges. I am able to access all the bridges at the main office, but I can not access any of the remote bridges. I check to make sure they have signal, and all are showing to be connected at the typical signal strengths.
I switch back to the D-Link and see if everything works, still no remote bridges. I reset the local bridges, they connect to the remote bridges but I still can't send any data across. So I go and reset the closest remote bridge, and everything works between those two bridges. At that point I thought I just needed to move to the HP switch and reset all the remote bridges, so I tried that. Radios would connect to each other, but I could not send any data through the connections. I switch back to the D-Link, reset the remote radios and I can access everything from any of the bridges.
I am thinking it has something to do with HP switch not mapping those remote bridges to its memory, but I have no idea how to correct the problem. All the radios have static IP addresses. Other than the problem with the bridges the HP switch works great. Any thoughts on what is going on or how to correct the problem?
