Man does NAIR suck....
GoingUp
So I got some of that free Nair for men and I was trying it out... It burns, it doesn't remove damn near any hair.... and I'm pretty sure youre not supposed to bleed after you use it..... If you get a free sample, throw it out and dont bother using it..... the little part of my chest that I tried it on is on fire right now
LOL! NAIR for men. They just slap the words "for men" on there and charge you another 50% to feel like you are getting some specially formulated product or something.
You must not have done it right. I've Naired my friend's back a couple times, and it's worked fine.
after many years of using it i guess my skin just copped out because i started getting caustic burns from it. i stopped using it a few years ago.
Originally posted by: freakflag
OK, I have to ask. I don't really want to, but, I have to.
Why are you using Nair on your chest?
This the one that Richard Simmons sells on late night TV?
I didn't need to know that.
:disgust:
Sure...your "chest."
Cause youre not supposed to use it on your wang 😛
Burns like hell and doesnt work though!
You're supposed to test it out first because some people are really sensitive to the lye in it. I use it on my back all the time and it's great! It feels like a mild sunburn for a few minutes after 10 minutes, but it takes away my bear-hair and leaves it smooth 🙂 A little aftershave takes the burn away. Your skin just sounds sensitive.
I do have very sensitive skin.... no more nair for me
you know you're supposed to test it out on your forearm or something before applying fullscale dude
its probably in instructions on the bottle but even if not, common use some common sense
every drug out there illicits an allergic response in a certain percentage of people, that percentage though small, does exist and its the responsibility of the user to make sure its safe, after all its YOUR body that YOU chose to use it on
so blanket statements about the quality of the product is unwarranted, but i sympathize with you on whatever sensitive burning you've experienced
welcome the the modern world of pharmaceuticals (SP?)
"So I got some of that free Nair for men and I was trying it out... It burns, it doesn't remove damn near any hair.... and I'm pretty sure youre not supposed to bleed after you use it..... If you get a free sample, throw it out and dont bother using it..... the little part of my chest that I tried it on is on fire right now"
Uh-oh! Someone's removing hair from his chest! :Q
Well, I'm not a guy, so I guess this wouldn't be applicable? Hope you find something better. And please spend some money for what you like. You get what you pay for. 😛 😀
well Mrs. Hairless Advocate... what would you recommend instead of shaving?
LMFAO. God... that had me laughing for a long time. Yeah, I don't think you're supposed to bleed man. Anyway, NAIR is for thin haired blonds with little wisps they want to remove. If you're using it on your chest, you're suicidal. But enough with the hair removal. If you're in such bad shape (ape'ish) consider taking hormones or something.
I thought chest hair was back in?
not the Ron Jeremy(back hair) or Robin Williams(a rug) kind, but the Tom Selleck kind.
uhhhh ok :Q
