MammaMia! Italians find water on Mars
DigDog
14,776
3,070
The Agenzia Spaziale Italiana, together with other Italian aerospace agencies, has aanounced they have found a 20km -wide saltwater lake under the southern icecap on Mars.
EN link: https://www.bbc.co.uk/news/science-environment-44952710
Science & Environment
Liquid water 'lake' revealed on Mars
By Mary Halton Science reporter, BBC News
Researchers have found evidence of an existing body of liquid water on Mars.
What they believe to be a lake sits under the planet's south polar ice cap, and is about 20km (12 miles) across.
Previous research found possible signs of intermittent liquid water flowing on the martian surface, but this is the first sign of a persistent body of water on the planet in the present day.
Lake beds like those explored by Nasa's Curiosity rover show water was present on the surface of Mars in the past.
However, the planet's climate has since cooled due to its thin atmosphere, leaving most of its water locked up in ice.
The result is exciting because scientists have long searched for signs of present-day liquid water on Mars, but these have come up empty or yielded ambiguous findings. It will also interest those studying the possibilities for life beyond Earth - though it does not yet raise the stakes in the search for biology.
The discovery was made using Marsis, a radar instrument on board the European Space Agency's (Esa) Mars Express orbiter.
The proposed lake sits beneath ice near the south pole of Mars
"It's probably not a very large lake," said Prof Roberto Orosei from the Italian National Institute for Astrophysics, who led the study.
Marsis wasn't able to determine how thick the layer of water might be, but the research team estimate that it is a minimum of one metre.
"This really qualifies this as a body of water. A lake, not some kind of meltwater filling some space between rock and ice, as happens in certain glaciers on Earth," Prof Orosei added.
How was it found?
Radar instruments like Marsis examine the surface and immediate subsurface of the planet by sending out a signal and examining what is bounced back.
The continuous white line at the top of the radar results above marks the beginning of the South Polar Layered Deposit; a filo pastry-like accumulation of water ice and dust.
Beneath this, researchers spotted something unusual 1.5km under the ice.
"In light blue you can see where the reflections from the bottom are stronger than surface reflection. This is something that is to us the tell tale sign of the presence of water," says Prof Orosei.
Image copyright USGS Astrogeology Science Center, Arizona State Un
Image caption Artists' impression: Marsis data shows an area of high reflectivity (dark blue) which is thought to be water
What does this mean for life?
Nothing definitive. Yet.
Dr Manish Patel from the Open University (LOL) explained: "We have long since known that the surface of Mars is inhospitable to life as we know it, so the search for life on Mars is now in the subsurface.
"This is where we get sufficient protection from harmful radiation, and the pressure and temperature rise to more favourable levels. Most importantly, this allows liquid water, essential for life."
This principle of following the water is key to astrobiology - the study of potential life beyond Earth.
So while the findings suggest water is present, they don't confirm anything further.
"We are not closer to actually detecting life," Dr Patel told BBC News, "but what this finding does is give us the location of where to look on Mars. It is like a treasure map - except in this case, there will be lots of 'X's marking the spots."
Image copyright Science Photo Library
Image caption Astrobiologists study extreme environments like salt lakes on Earth to understand how life might survive on Mars
The water's temperature and chemistry could also pose a problem for any potential martian organisms.
In order to remain liquid in such cold conditions (the research team estimate between -10 and -30 Celsius where it meets the ice above), the water likely has a great many salts dissolved in it.
"It's plausible that the water may be an extremely cold, concentrated brine, which would be pretty challenging for life," explained Dr Claire Cousins, an astrobiologist from the University of St Andrews, UK.
What next?
While its existence provides a tantalising prospect for those interested in the possibility of past or present life on Mars, the lake's characteristics must first be verified by further research.
"What needs to be done now," explained Dr Matt Balme from the Open University, "is for the measurements to be repeated elsewhere to look for similar signals, and, if possible, for all other explanation to be examined and - hopefully - ruled out.
"Maybe this could even be the trigger for an ambitious new Mars mission to drill into this buried water-pocket - like has been done for sub-glacial lakes in Antarctica on Earth," he added.
The area has been compared to Lake Vostok, which lies 4km beneath the Antarctic ice
Scientists have previously claimed to find bacterial life in the buried depths of Antarctica's Lake Vostok, but drilling on Mars would make for an ambitious project indeed.
"Getting there and acquiring the final evidence that this is indeed a lake will not be an easy task," said Prof Orosei.
"It will require flying a robot there which is capable of drilling through 1.5km of ice. This will certainly require some technological developments that at the moment are not available."
The findings were reported in Science.
Having secured both water and salt, Italians are looking at sourcing other key pasta ingredients directly on mars; "prospects are good" said professor S. Upermario, later adding "mammamia" and "erewego!".
May 11, 2008
22,924
1,506
About 300 years from now :
We brought about 10 liters of the water back to earth in 2036.
And that children was the start of the accelerated evolution, and is why we now can see the entire electromagnetic spectrum and have 4 arms and two legs.
Who knows what a mutagenic organism is ?
May 11, 2008
22,924
1,506
ultimatebob
25,134
2,450
Is that supposed to be an Italian pasta factory on Mars? I guess that you could fit the big mixers in those buildings.
May 11, 2008
22,924
1,506
They look like the nose cones of rockets being send to mars one after the other.
Be prepared to eat pizza from a tube. Or use a pill that when hydrated turns into a prebaked pizza that can be heated in a microwave.
Was the microwave not a nasa invention ?
BurnItDwn
26,355
1,867
That mars buggy looks about as fast as a golf cart. Distance from Mars to Toronto is around 225 million KM. Might take a while ....
Reactions: Mayne
