Making two gigabit lan ports
servin247365
240
Ok, this may sound crazy, i have a L1N64-SLI-WS board it has two gigabit lan ports, i want to make them run together to make it run at two gigabit? Is this possible
Thanks,
Jordan
USAF
Madwand1
3,309
nVIDIA has teaming support which could be used for this purpose, but it has the standard limitations.
The problem with most implementations is that it's still not possible to have a single connection / conversation go over both ports simultaneously. So if you get it working well, it might be good for a server, which hosts many clients concurrently (and then you'll be bottlenecked on the rest of the system if you manage to beat the gigabit bottleneck), but not useful for client computers themselves or file transfers run one at a time.
Alacritech has a readable article on the topic:
http://www.alacritech.com/Supp...Documents/Teaming.aspx
JackMDS
29,546
422
It does not sound crazy, it is crazy ;)
What you are asking about is called NIC Bonding/teaming, it can not be done with regular Motherboard NICs and Client OS.
You just have to let go and live with the "disturbing" idea that you have a $5 worth of useless NIC on your Mobo unless you configure a separate Giga Network.
Home Giga Network: http://www.ezlan.net/giga.html
Giga networking - http://www.ezlan.net/giga_net.html
nightowl
1,935
So, not only do you need OS support and driver support to bond 2 NICs together into what is commonly called EtherChannel you also need a switch to support the aggregation as well. Also, one thing to keep in mind, you will never be able to transmit more than 1 Gig per flow and when I say flow, I mean something like a FTP session between 2 nodes, even if they both have 2 NICs bonded together.
JackMDS
29,546
422
The two NICs Motherboard are the evil invention of the Century.;) :evil:
Many users can Not Stand the idea that they have a useless component in their system.:brokenheart::shocked::|
xSauronx
19,582
4
hey screw you, im using both of mine at the same time
vmware ftw
/same thing, right? ;)
JackMDS
29,546
422
Originally posted by: xSauronx
hey screw you
I guess that Not knowing the difference between:
Many users (as posted), to all users (as you probably envision) really gets you out of control.
Many = a lot, but not every one.
All, would mean every one including you.
xSauronx
19,582
4
hey screw you
you may have taken me a tad too seriously.
