Making coasters with DVDshrink & TDK DVD+R's, HELP!
Lothar1974
1,133
I just bought these TDK 4x DVD +R disks and everyone has bombed at the end giving me this error:
8:47:55 AM #23 SCSI -1176 File Cdrdrv.cpp, Line 1203
SCSI Exec, HA 0, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x04
8:47:55 AM #24 CDR -1067 File ThreadedTransferInterface.cpp, Line 1626
Invalid field in parameter
PLEXTOR DVDR PX-708A\H0 T0
8:47:55 AM #25 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1626
Could not perform end of Disc-at-once
8:47:55 AM #26 Phase 38 File APIProgress.cpp, Line 238
Burn process failed at 2.4x (3,312 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.2.0.110 , size=24698 bytes, created 2/8/2004 11:47:12 PM
I used Memorex DVD -R before and didn't have any issues, anyone have any thoughts? I have a plextor 708A. Thanks
Lothar1974
1,133
It will burn all the way to the end 100 % and error out when finalizing the disk. Does anyone have any ideas? Thanks!! P.S. I have tried it at different speeds closed any programs, memeory should be enough I have 2gig processor is a P4 2.53.
Brian48
3,410
Had similiar problems when I first started backing up DVDs. Fixed it by switching the media I was using. For movies, I've found that DVD-Rs were more reliable with my Lite-On 851S.
Lothar1974
1,133
I email Plextor and this is what they suggested: Please update your motherboard bios and eide controller drivers from your motherboard mfgr. Also, try adding a jumper to the DMA pins on the back of
your drive, as some ide controllers work better in that mode.
Does this sound pliable to anyone?
Brian48
3,410
Sounds like the typical "I really don't know what's going on" response to me. Anyway, you can double-check your configuration as the email suggests, but I really don't think it's going to help.
DAPUNISHER
31,577
31,234
Make certain you flash your drive to the latest firmware revision for it.
Lothar1974
1,133
I have the newest firmware update. I think I will try the same DVD-R I was originally using and see if that makes a differnce, not that it should. If anyone has any other ideas I appreicate it. Thanks!
