- May 10, 2004
- 239
- 0
- 0
I've noticed a lot of pictures of case mods and lots of in depth explanations and guides to people doing a full blown mod of their case. Right now I really don't have the time to do that, but I've been having problems with temps for a while and want to solve it. All I want to do is make either a hole for a 92 mm fan or a 120 mm fan in the side of my case, and be able to put a filter on it to keep most the dust out.
http://www.boomspeed.com/earthslash/CompSide1.jpg
http://www.boomspeed.com/earthslash/otherside.jpg
Theres a couple pics of both sides of the case (a bit big, sorry 56k users). As a temporary solution I used masking tape to put a 80 mm fan in the spot where a floppy would usually go (though I don't use a floppy). My cpu temps went down 6 or 7 c with that one fan alone. But this isn't permanent because its getting dust in my case, and I'd like to not have a fan there forever. Anyways I'd like to put a fan in the side of my case, but I don't really feel like going out and buying a bunch of expensive tools to do one hole. I don't want to ruin the side of the case either doing something without anyones advice, because I don't have any experience with this sort of stuff. Any suggestions on a decent way to do this? (best tool, suggestion on a fan, whatever is appreciated). Thanks.
- Steve
- Steve
