Making a DOS Thumb Drive
dmw16
Sorry, wasn't sure where to put this.
Does anyone know how to make it so I can boot into DOS using a thumb drive?
THanks.
Remember that most versions of DOS have a pretty low partition size limit. I tihnk it was 2GB. Don't try to use a 4GB drive unless you get some new version of DOS like Caldera.
I found an application that should load a bootable ISO of FreeDOS onto my thumbdrive. Hopefully that will work then I can just dump the two other files I need onto the drive. We'll see how it goes...
