Making a Bootable WinXP CD - Help!
saber800
425
I am trying to make a WinXP bootable CD but I'm having problems. I tried using Roxio with no luck. In Roxio, I select Floppy Emulation, insert a bootable floppy and create the cd (with WinXP files copied too). When I restart, my pc boots from the cd but I can not see or access the WinXP files (i386 dir), only the files that were on the floppy.
The reason I'm making a boot cd is because my new Compaq 6000Z didn't come with WinXP Home CD-ROM but it did have the i386 dir on the c: drive. So I'm trying to see if I can make a WinXP Home Install CD by copying the i386 dir and making the cd bootable.
Any help would be appreciated!
Thanks
kt
6,032
1,348
Go here. It has instructions and the necessary XP bootable files for you to download.
