Making a bootable CD without a floppy drive
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
I'm running Windows XP Pro and I need to get to a DOS prompt. Nearly every site that has instructions on making a boot CD starts off by saying "first make a boot floppy". I don't have a floppy drive, but I need to boot to DOS - is there a way to make a boot CD that will take me to DOS (or DR-DOS) that doesn't involve a floppy drive?
Thanks for any advice.
Insidious
7,649
Easy CD Creator (V5.x) will let you make a bootable CD (choice of floppy or Hard Disk emulation)
Luke727
57
download a boot floppy image from bootdisk.com and use that to make your bootable cd.
pm
Jan 25, 2000
7,419
22
Thanks for the suggestions!
Great site, Luke727. That was exactly what I was looking for. I have Nero burning a boot CD right now. Thanks very much for your help.
Barnaby W. Füi
12,343
i was looking to do the same thing once, but all i found at bootdisk.com was exe's that asked you to insert a floppy!
i guess i didnt look hard enough :p
CTho9305
9,214
if its one of the text-based EXEs you're SOL, but if its a gui, they usually have checkboxes so you can just extract the image, or the files contained in it. I extracted the image to an IMZ, used winimage to make it an IMA, then made my 98se-DOS bootdisk. haven't used my floppy drive in a while :)
pm
Jan 25, 2000
7,419
22
I ended up doing exactly what CTho said. It extracted a .IMZ and I used Winimage to make that a .IMA and then burned that with Nero and then booted off of that.
Thanks for the suggestions.
