Alright, I really have some major problems with this motherboard...
Firstly, I have gone through 2 AthlonXP 2500+ Bartons and both didnt work....but I pop in my 1800+ Palomino core and it works fine....ok, so maybe its my Processor, but 2? Thats some coincidence...
And my graphics problem, which will probably end up with me RMAing the motherboard, or going with another brand...
Firsly, my 9800pro got major artifacting during 3d gameplay/benchmark, but 2d stuff like web surfing, etc. it was fine. Basically blamed it on the graphics card so ATI has it right now...
Bought a Radeon 9200 non pro and that just freezes during 3d gameplay after about a minute or two....ok...returned it....
Bought a nVidia GeforceFX 5200......same problem ast the 9200...
Ive finally narrowed it down to the motherboard since Ive gone through 3 video cards.....even a different brand and all still have some pretty bad problems during 3d...
So I ask you, has anyone else had these types of problems with their MSI board, or should I ::sigh:: go ahead and RMA or return it....Im interested in going with that Soltek nforce2 board.....this is really an inconvience...I really thought this board would do wonders for me....apparently not..
AMD AthlonXP 1800+ Palomino core
2x256mb Kingston HyperX PC2700 DDR333 @ cas 2 2-2-2-5-1t dual channel enabled
eVGA GeforceFX 5200
MSI K7N2 Delta-L w/ nforce2 Ultra 400 chipset
Maxtor 40 gig and 80 gig HDs @ 7200 rpm
Sound Blaster Audigy Gamer
Turbolink 420watt PS
+3.3 - 28A
+5 - 40A
+12 - 18A
Which isnt great, but should be enough to run said system fine since it ran the 9800pro, if I cant find a fix here and have to RMA the board and that doesnt work, probably go with a better PS...but positive it isnt the problem..
For cooling the processor, Im using a Thermalright SK7 (all copper, great heatsink) and a Thermaltake SmartFan II - processor temps under 30 degrees C when not overclocked..also have 2 case fans one sucking in on the front, and one sucking out in the back...
I honestly believe the problem is something the AGP port since these video cards seem to be overheating...at least thats what I believe was the problem with the 9800pro, the problems it shown were symptoms of overheating issues, maybe get a PCI fan to help the problem since the cooling on these cards are minimal (both the 9200 and the FX 5200 dont have fans, and the 9800pro hs and fan dont seem very effective, but it has been known to run hot)
Im running out of ideas here...I really dont want to have to RMA the board, but I may have to. Ive already RMAed my processor, got it back yesterday and it doesnt post (the lights on the little box thing that comes with the mobo says the processor is damaged or not installed properly, but I know it is since I put in my 1800+ and it works fine)
I know the ram is fine (ran memtest overnight, no problems whatsoever) and I have tried another stick of 512mb DDR266 PC2100 and that gave me the same problems...
- vicks
eVGA GeforceFX 5200
+3.3 - 28A
+5 - 40A
+12 - 18A
- vicks
