Hello everyone, I have a brand new PC and the temperature of the CPU is really bad. I have called Intel and they can only help me after I've had the CPU for 30 days (which is still another week off...).
In the meantime, I need to try to figure out what the problem is, incase they don't help me very well. And I need to know if I should be getting a replacement CPU or HSF or what.. I really have no idea what I should do, so I really need advice from you guys.
My CPU and everything else in my PC, is running at stock speeds. Using an "Arctic Cooling Pro 7" with Akasa 5022 Pro+ Grade Themal Compound. Fan is at about 1400RPM which goes much faster when the PC is under load. I also have two silent 120mm case fans, which dont move a whole lot of air, but are better than nothing. Nothing is Overclocked. Here are my temps:
Intel TAT:
52 Idle
64 Full Load on both cores.
SpeedFan:
38 Idle
52 Full Load (using intel TAT to provide the load)
Those temperatures are when my room is toasty warm. When the temperature of my room is cooler, all those temps go down by several degrees, but its still too hot, and my room is really cold then. The temps with Intel's Stock Cooler where about the same.
I have re-fitted the CPU and Heatsink about 10 times, and done a thorough cleaning of the Compound every time, and reapplied it each time. One time I used a bit more than usual. One time I used very little. The temps only really vary by a few degrees each time. The best I have had it, was about 3 degrees cooler than I listed above. The HSF has its little white pins sticking through the other side of the motherboard, so it seems like its fitted properly.
So please help me and suggest what to do. To return the CPU to where I bought it from, I will be without a PC, and they will charge me if they test it and find that its within reasonable temperatures. I could just buy a new HSF and see if that was the problem, but I can't see anything wrong with this one, and it would be a waste of money to buy another one, only to get the same temperatures.
I really have no idea what to do
p.s. My "CoreTemp" temperatures are about the same as Intel TAT. My BIOS reports temperatures similar to "SpeedFan".
Intel TAT:
52 Idle
SpeedFan:
38 Idle
