how do i reset ram...and i got all the info into a html file, here is what i got, tell me if you guys notice something fishy...thanks
CPU(s)
Number of CPUs 1
Name Intel Pentium 4
Code Name Prescott
Specification Intel(R) Pentium(R) 4 CPU 3.00GHz
Family / Model / Stepping F 3 3
Extended Family / Model 0 0
Package mPGA-478
Core Stepping C0
Technology 0.09 µ
Supported Instructions Sets MMX, SSE, SSE2, SSE3
CPU Clock Speed 2992.7 MHz
Clock multiplier x 15.0
Front Side Bus Frequency 199.5 MHz
Bus Speed 798.0 MHz
L1 Data Cache 16 KBytes, 8-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 1024 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 2992.7 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
Mainboard and chipset
Motherboard manufacturer soyocomputer
Motherboard model P4IPE, 1.X
BIOS vendor American Megatrends Inc.
BIOS revision 080009
BIOS release date 06/10/2004
Chipset Intel i865P/PE/G/i848P rev. A2
Southbridge Intel 82801EB (ICH5) rev. 02
Sensor chip Winbond W83627HF
FSB Select 800 MHz
Performance Mode disabled
Graphic Interface AGP
AGP Status enabled, rev. 3.0
AGP Data Transfer Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
DRAM Frequency 199.5 MHz
FSB
RAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 1
Module 0 Corsair DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
