major problems
JellyfishMan
9
i just put together a new system, aopen mk33 and a duron 700mhz.. i cant get the system 2 stop freezing.. i have tried 3 differnt sticks of ram, a geforece 2mx and a voodoo 3 pci.. 2 different hard drives and it always crashes.. should i be installing speical motherboard drivers or anything i should know about?
thanks
JellyfishMan
9
the powersuppy came from mwave.com nd the motherboard was installed in it witht he duron so i assume they wouldnt give me a crap powersupply with it
Mem
21,476
13
See if you can find out what PSU you have, open the case have a look,you may need to unscrew the top cover of case to see the brand & model type & power rating,did you do a clean install,& have you installed the Via 4 in 1 drivers?Post your specs like board,OS etc.
