Here I go again searching for help from you guys.... oh well...
The problems is: After installing a new disk and applying some new Artic Silver 3 the computer starts up but gives continuous beeps. I have tried everything to my knowledge in regards to Computer. When giving this kind of error the first thing to do is strip the computer of all parts and start connecting them one by one. The problem is down to either the board, the CPU or the PSU (I think) because I have tried to connect only this components and the error is still there.
I even tried to unplug the memory modules to see if the error code (beep codes) was the same but it isn't. The error I get is a slighltly longer continuous beep.
When I connect the PC all the fans and all the drives seem to work. (at least the fans spin and the drives give the startup sound but I get no image in the monitor (it isn't the graphics card because I have already tried the TNT2 that I have at home and it keeps with the same error codes). The floppy drive doesn't check for the disk @ startup (although I think this is normal because the computer doesn't start the boot sequence due to the error). If it was the CPU, would the PC start up all the fans and stuff? How can I know for sure which component is causing the problem? I am going to check a different PSU from a friend to see if it's from the PSU.
Any ideas? thanks!
PS: I already checked the CPU to see if it is cracked or fried but everything is ok (apparently).
PS nº2: I also forgot to mention that I already reset my BIOS to all default values...
Any ideas? thanks!
