Major Problem
TMoo
49
I just got a new Visiontek GeForce3 64mb card. I am running a fresh istall of Win2K, Via 4to1 v4.32 drivers, Detonator3 12.41 and Direct8. The problem that I am having is that when I run 3Dmark2001, it will go through all the tests and then tell me that it did not run enough tests to give me a score. It seems that I am failing on the high res tests. Usually just one but sometimes two of them. After testing for a while and reloading the above drivers a few times, I will get one complete test in, with a score of around 4880. I don't know what is going on and after gaming with this new card, I am not impressed with the frame rates that I am getting. I know there is a problem with my setup and everything will get better once I figure out what is going on. Check out my Rig and tell me what you think. I even began pulling out sticks of ram, changing the AGP settings in my bios and even removed sound card and ethernet card. I am also running SP2 for Win2k. Anyone know a solution to my problem?
P.S. This also happened with a Creative GeForce2 32mb card. I thought the card was bad so I upgraded. Also, once in a while, I will suddenly loose the option to test my AGP texturing in dxdiag. The button will be grayed out and you also wont be able to disable any of the tests. I wont be able to play any of my games and keep getting dropped back to my desktop. The only way I have found to fix this is to reformat.
gipper
60
Microsoft and Via both have a fix for agp cards in the via chipset with win2k. I'm not sure whether it made it into W2k spk2 or not. You can get it from microsoft's web page. It takes some searching to find it, but start with the w2k home page. That could be a part of it.
TMoo
49
That update was for SP1. It tells me that SP2 already includes the fix. Thanks for your help.This problem is so weird.
TMoo
49
I figured out the problem. In Win2K, ACPI assigns everything it can to IRQ 9. I had to set ACPI to standard PC and then it put everything on different IRQ's. But now Motocross Madness locks up and never has before. hhhmmm
Darkluck
Two words for you: LATEST BIOS!
I had similar problems with 3d on my setup when I put it together. I would highly suggest never to use beta drivers from nvidia....make sure they say Microsoft WHQL certified otherwise you are taking your chances. You can get a bunch of different versions of the drivers from the-ctrl-alt-del.com, including the latest ones.
TMoo
49
I have the latest drivers. I will wait for the release of the Detonator4 drivers later this week.
