- Jan 30, 2001
- 17
- 0
- 0
I have a Tyan Thunder i840, and no matter what I do, the on-board NICs will not work. I've called Tyan, they told me to try a few things (already done, very basic troubleshooting procedures), but nothing helps. PLEASE help me! I get the following errors under Win2k on boot that deal with the NICs (found in Event Viewer):
Source: E100B
Event ID: 5004
Intel(R) PRO/100+ Management Adapter : Could not connect to the interrupt number supplied.
Data: (in words)
0000: 00080000 005c0002 00000000 c000138c
0010: 00000000 00000000 00000000 00000000
0020: 00000000 00000000 0000001a 00000009
Source: E100B
Event ID: 5004
Intel(R) PRO/100 VE Desktop Adapter : Could not connect to the interrupt number supplied.
Data: (in words)
I have the on-board SCSI disabled both via jumper and in the BIOS (latest, version 1.02). The LAN adapters are enabled (jumper is open on the motherboard, closing it disables them), but I see no BIOS options for them anywhere... the only BIOS options changed from defaults are the following: "Memory ECC" is set to "H/W ECC" (the RD-RAM is ECC), "PnP OS" is set to "Yes", "ACPI Aware" is set to "Enabled", and the on-board SCSI is disabled through a BIOS option.
There is only one add-in PCI card installed, which is the Adaptec 2100S SCSI RAID controller (latest firmware, 3607 I believe) in PCI slot 6. The system is running Win2k Server (no service packs yet, as it has not been able to get online due to a lack of a network connection).
Would installing SP2 help? I would sincerely appreciate any and all help I can get with this, and I will post more relevant information as I find it. Please feel free to respond with a question, as it will aid in my diagnosing the problem. Thanks!!!!!!
Source: E100B
Event ID: 5004
Data: (in words)
Source: E100B
Event ID: 5004
Data: (in words)
