For the average user, the difference pretty much ammounts to price. If they're running a complex network for some reason, or have 2 physical CPUs (not dual core), or have some need for remote desktop, pro would be a better choice, but these aren't exactly 'average' user scenarios.
This thread gets two :thumbsup::thumbsup: for not following the usual route of Home vs Pro threads.
Home is fine for pretty much everything you want to do.
If you're an experienced user, then you'll know why you need Pro.
Pro works well with others. So if you add a pc in your house 1year from now, setting up a network and shared folders will be SO much easier. Spend the bones, get PRO.
