Ok, here are the symptoms i have been facing over the past year or so......
Well actually, before i explain to u the symptoms i should tell u how it all started.
My WinXP was ultimately messed up back in January, and i thought it was due to the fact that i had accidentally rewritten the current registry with a backed up registry (double clicked on the backup registry). So I decided to reinstall WinXP only to find out my RAM was the problem. So I bought new RAM, installed it, and reinstalled WinXP. Here is where the big big big problem began.
I started to notice weird screen artifacts and odd symptoms (This with all the same hardware from when my comp was fine except for the new Micron RAM)
These include the following
- Lag that I had never encountered before (Took twice as long to load Windows)
- Weird Screen Artifacts (http://members.rogers.com/erastrada/wtf.jpg)
- When I right click on a file and I hold my mouse over a command without clicking on it for more than 5sec, and my sound starts to skip every 2 or 3 seconds.
- My Kazaa I installed wouldn't work and would give me a fatal error (never happened before?)
- Odd lag when playing CS... It almost seems like I skip a frame every 2 or 3 seconds while playing, and the lag intervals are constant.
- Lag when I move my windows around on the desktop where I can see disfigurement of the windows while dragging (the effect u get when ur comp is on full load and you are trying to move windows around)
- Extremely long load times
So basically all my symptoms come out to one simple conclusion of .... Major LAG and F***ed up ness!
After a series of performance tests using 3DMark2000 and SiSoft Sandra, I concluded my performance was fine according to benchmarks.
My CPU, HD speed, and my RAM speeds were up to par and some even exceeded.
After upgrading my comp and installing a brand new motherboard, ram, cpu, harddrive, cdrom, dvdrom, case (lol), and even a new mouse and keyboard.... I still seem to be getting the exact same symptoms even after 3 full formats except for.......
But the rest of the symptoms still remain.
The conflicted hardware may be the following......
- RAM
- Soundcard
- ATA Cables
The things I can definitely rule out since they are brand new and the symptoms still stayed the same even during hardware swappage between the old and new parts are......
- Mobo
- CPU
- Vidcard
- CDROM
- DVDROM
- HDs
- Monitor (Dunno, but some ppl can think up crazy reasons)
So here's all the information I can give you to my problems. Please contact me via e-mail (dibble@rogers.com) or ICQ# 103588302 if you have a good idea as to what the problem may be. The best prediction I can give to what the problem may be is the RAM having a bottleneck problem in which there isn't enough bandwidth between the Mobo and RAM. More or less an affect of having a pipe clogged up with leaves and only a little bit of water can get through. or another reason might be that the ATA Cables are damaged so there isn't enough bandwidth between the Mobo and HD's. This causes the extremely slow transfer speeds (which is untrue when u look at SiSoft results) causing the lag. Or perhaps the benchmark isn't detecting the 0MB/s transfer rates during the lag times so it simply ignores them or counts them as an error. I don't know, there's a billion reasons why something could be wrong.
I just want a theory or an opinion as to what would be causing the big problem when u look at all the symptoms above.
Thank you for taking the time to read this, thanks! I'm a man in need of great help! (lol)
This problem has boggled a lot of comp genius's minds. I've never had such a comp problem like this, or a comp problem i couldn't fix.
- RAM
- Soundcard
- ATA Cables
- Mobo
- CPU
- Vidcard
- CDROM
- DVDROM
- HDs
