I've currently got an Albetron 845 PVE Pro and am in the process of seeking a replacement due to what I believe to be a bas board. However, before I go down the road of rebuilding the machine, I thought I'd through out a hand and ask for the opinions of some folks around here as to if anything else could be the issue.
The Hardware:
Albetron 845 PEV Pro
1gig Crucial PC2700 RAM
Hercules Sound Card
1 80gig Maxtor ATA 133 HDD
2 200gig Maxtor ATA 133 HDD
9800 Pro video card
Enermax 440 power supply
The Problem: About 3 months ago, whenever I booted up my machine, it would occasionally not see some of the drives. I'd have to reboot, go into the bios and manually search for the drives for it to pick them up. After replacing my Lite-On CDR with a DVD burner, the issue was magnified to the point where the machine would routinley lock up and I coul hear the drives spinning up/down repeatedly as I tried to run applications. On boot, my Maxtor drives would also sometimes be seen as M@x }^&t0 drives (always appeared as jibberish).
My current situation: I have replaced drive cables, swapped RAM, flashed bios and swapped drives and the issue is still present. Currently, if I place more then one drive in the machine, the machine will lock-up or I receive a disk boot failure. I then have to unplug the drive, reboot, plug the drive back in and then it boots fine. I've checked my temps and voltage, all look fine and well within spec.
At this point, the only thing I can think is that the board or the PSU is bad, but as the issue seems to be HDD related and I have swapped all those, I am leaning towards a board issue.
Any ideas?
The Hardware:
Hercules Sound Card
9800 Pro video card
Any ideas?
