jlateralus
I just flashed the bios on my A8N-SLI Deluxe from 1003 to 1011. When I rebooted, all of my bios settings were gone. The problem is that I cannot boot into Windows XP anymore. I have two raptors in a striped array on Nvidia Sata channels 1 and 2. When Nvidia raid is disabled, the bios detects that there are two drives on channels 1 and 2. Of course, then I cannot boot into Windows. So, I enable the Nvidia raid on Sata channels 1 and 2 and reboot and I cannot boot into XP. When I go back into the bios, it shows that no drives are on Sata channels 1 and 2. So, if I enable Nvidia raid, the bios thinks that no drives are connected to channels 1 and 2. If I disable the Nvidia raid, then the bios detects that I have two drives connected but I cannot use them since they are in a raid array.
Wih Nvidia raid enabled, I checked on the array and it reports it as healthy and it is set as boot.
Does anyone have any ideas?
