mainstream oil immersion cooling!!
dude if i got sponsored for such a rig.
I think i could make it a ton better.
Forget oil submerssion. Thats not for the normal person. Also, you wont get much overclocking out of that.
Trust me, i know that setup, and that poor magicool radiator wont handle it. Maybe if they used the Xtreme version which fits 9 fans.
I like that passive system better that the guy made and this watercooling setup has me absoutely speachless, however he mixed metals, but OMG the work is speachless.
http://www.explosion-zone.ch/f...f5fe6939cf8bc29&page=1
Originally posted by: Stern
That. Is. One. Sick. Case. I wonder if he makes them on order 😛
if my custom builders are correct, that waterblock alone would cost 500-600. Because of all the machine time involved. 😛
That case looks amazing...only thing is though that if he decides to change components it looks like it's another custom job for most of the components.
Regardless though...WOW. :Q
That case is SO AMAZING, there are no words. I did, however, notice SilenX fans... bad choice on his part.
BUT THAT IS SO AMAZING.
Realy? That case looks like a modded version of XBox 360 case (in Black). Doesn't look all that appealing to me.
I just found out about this, and a friend of mine knows the lead designer of this project. I'm likely going to pursue an engineering internship there, it's very close to where I live, I'm pumped!
tell him to use the magicool xtreme radiator instead which has 9x120.
As the system stands right now, you will overheat with 3x280GTX, gaurentee'd expecially if ambients are hot, and your overclocking in the 4ghz range.
And if they say im wrong, tell them to come here and check out my sig.
aigo didnt you have like 6 q6600 rigs in there at one time also? or was that someone else. you should totally add all those back in if they were all on water lol. just seeing anyone with a sig that has 6 quads in it all at 1ghz+ OCs is pretty funny. i would love to have a farm like that
6600? :rofl:
yes and then i had 7 yorkies at one time also. :rofl:
Picked the best out of those and kept the 4.
The 4 yorkfields i have now produced as much as my 6 Q6600 i had back then while using less energy. I love the overclocking wall on E0 yorkies. 😀
What makes them think it's oil?
Oil is an insulator plus they have non-conductive fiulds with decent heat capacitance/viscosity/water like like 3m Fluorinert.
If I had to bet it's not oil.
